查看: 6638|回复: 0
一行代码安装ROS
发表于 2021-9-20 11:40:05 | 显示全部楼层 |阅读模式 来自 中国陕西西安
一行代码安装ROS
  1. wget http://fishros.com/install -O fishros && . fishros
一行代码安装ROS2
  1. sudo apt-get install curl && curl https://ghproxy.com/https://raw.githubusercontent.com/igeekiot/ROS2/main/install_ros2 | bash
GMT+8, 2026-3-1 19:55 , Processed in 0.069335 second(s), 19 queries .
